[mapguide-internals] Re: Another installer test...
Jason Birch Jason.Birch at nanaimo.ca
Sat May 16 03:38:44 EDT 2009
Kenneth,
If you get a chance, could you please try out the latest (0.7) installer from:
http://download.osgeo.org/mapguide/testing/
I explicitly set the permissions on all of the MapGuide directories to Anonymous only, so if there are still problems I don't think I have an answer.
Jason
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
> Sent: Wed May 13 00:46:06 2009
> Subject: Re: [mapguide-internals] RE: Another installer test...
> After installing on Win 2K3 R2, with IIS ASP.Net,
> the mapagent has "integrated authentication" enabled, which causes all
> requests to be denied (authentication failed).
> I'm not sure why that is enabled, or if its fixable in the installer.
More information about the mapguide-internals mailing list
