[mapguide-internals] Installer status
Jason Birch Jason.Birch at nanaimo.ca
Mon May 18 13:07:55 EDT 2009
I'm not sure.
That does seem a bit insane, but I don't know what levels of redundant temp files NSIS (compressed EXE) and the bootstrapper (bundles up vc runtime) add on top of the msi process.
I know I tried everything I could think of to get the installer to report a lower (than 1.4) requirement, but failed.
You can unpack the EXE using a recent version of 7-zip, and pull the MSI and VC runtime out to run directly...
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Mon May 18 09:51:05 2009
Subject: Re: [mapguide-internals] Installer status
Me again...
It's the crazy free-disk-space requirements!
I started with not enough space to start the installer process... that is
where the installer just hangs.
I now have 1.9GB free and that is not enough to do a minimal IIS/.net
install process.  Once the 480MB MSI has been extracted once and then again
to TEMP folders the installer says I need 1.3GB free... so before you start
the download you need:
 1 x  100MB (.exe)
 2 x  480MB (.msi)
 1 x 1300MB (install - is this right?)
So really before starting to download you need 2.5 GB free?!
 Crispin
Crispin_at_1Spatial wrote:
> Hi,
> Hate to potentially put anything in to slow this process (especially as XP
> is a development, not deployment, environment) but... new XP VM, SP3, IIS,
> .net 2.0 and the installer (0.7) just runs through "Extracting Files.
> Please Wait" and then sits in task-manager doing nothing... I can't even
> find the extracted files to run the MSI with logging.  Is there a way to
> have logging on the EXE?
>  Crispin
View this message in context: http://n2.nabble.com/Installer-status-tp2911800p2934280.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
