[mapguide-internals] RE: Rendering engine issue
Traian Stanev traian.stanev at autodesk.com
Tue Nov 17 12:08:06 EST 2009
Looks like you zoomed in beyond double precision limits. However, it seemed to me like it was useless to zoom in so far, since all you were doing was zooming in on a single point.
If you want to zoom in further without artifacts, I recommend changing the coordinate system of your data such that the origin (0,0) is somewhere near the area of interest.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ivan Milicevic
Sent: Tuesday, November 17, 2009 4:31 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RE: Rendering engine issue
I would be delighted to do that! :)
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, November 17, 2009 9:56 AM
Subject: Re: [mapguide-internals] RE: Rendering engine issue
what resolution is the data?
if you post a mgp to a trac ticket it would be great :)
z
2009/11/17 Ivan Miličević <Ivan.Milicevic at supranet.hr>
> Hello Kenneth,
> Double checked; no double lines, single layer, clean lines, various line
> width, map space and device space units... The behaviour is same.
> Scale is small, everything bellow 1:100000 (meters, projection is LL84 -
> WGS84) is falling apart. MG seems to be just fine (memory is fine) and error
> log is empty.
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede,
> GEOGRAF A/S
> Sent: Tuesday, November 17, 2009 9:31 AM
> It seems as if there is a bug in the rendering engine.
> Try adjusting the linewidth to see if it gets better.
> Also make sure the line data is clean, eg. no double lines etc.
> This is usually due to rounding errors, what scale are you zooming in at?
> Anything below 1:50 makes my MapGuide use extreme memory and often crashes.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Ivan Miličević skrev:
> > Anyone see this???
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ivan Miličević
> > Sent: Tuesday, November 10, 2009 1:18 PM
> > Subject: [mapguide-internals] RE: Rendering engine issue
> > Ok, I can't attach via Outlook so, here is a download link:
> http://gis.supranet.hr/downloads/mg.zip
> > Sent: Tuesday, November 10, 2009 1:16 PM
> > Sorry,
> > here is attach.
> > Subject: [mapguide-internals] Rendering engine issue
> > Hello Internals,
> > i have noticed a strange behaviour of rendering engine when zoom action
> is performed.
> > Runned server is Mapguide 2.1 (Jason's ultra nightly beta build), OS is
> XPSP3 and browser is IE8.
> > Everything is in swf file (captured flash movie), so please take a look.
> > Should I open new a ticket for this issue?
> > It's interesting that AutoCAD Map 3D had the same problem a year ago.
> > Ivan Miličević
> > voditelj odjela razvoja
> > SUPRA NET d.o.o.
> > Majstorska 5, 10000 Zagreb
> > CROATIA
> > Mobile: +385 (0)91 434-3940
> > Office: +385 (0)1 434-3940
> > Fax: +385 (0)1 434-3999
> > Email: ivan.milicevic at supranet.hr
> > URL: www.supranet.hr
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
