[mapguide-internals] Re: 2.1.0 Final Windows Installer
Jason Birch jason at jasonbirch.com
Thu Nov 19 21:35:20 EST 2009
I can keep my local 2.1 build environment around for whenever that
patch happens. I think it may be more important for the current system
to track trunk as semi-continuous build system? Probably better not to
waste efforts on 2.1...
Oh. There's a doc somewhere on the osgeo website or wiki showing how
to submit major release news to OSGeo for announcement. That (and a
post to mapguide-announce & -users) are important steps.
On 2009-11-19, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Yep.  Check out from Linux and run an svn export to create a clean tree.
> The line endings change and I think the Linux checkout also makes a
> difference on the execute permissions for the various shell scripts.
> This might take me a couple of days.  I don't have a Linux development
> environment set up at the moment.  I should probably install VMware on my
> extra Dell box and go from there.  Not a big deal.  Just more busy work.
> I wonder if we should leave the existing Windows build VM at 2.1 instead of
> moving it to 2.2?  I suspect the community will want an MGOS 2.1 patch at
> some point.
> Thanks,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: November 19, 2009 6:44 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Re: 2.1.0 Final Windows Installer
> Cool.
> It would be great if we could post a tarball of the source checked out
> on linux (I think line-endings etc change?).
> Not sure if would be better to just zip up including .svn directories
> (good starting point) or to export from local repo for a cleaner tree.
> Maybe both :)
>> Hi Jason, I am updating the Drupal website.  Should we also post the
>> source
>> code as we did for previous releases?  I can perform the SVN checkout and
>> zip locally assuming we are using version 4283.
>> And thank you for your many tireless hours on this release!
>> Regards,
>> Trevor
>> View this message in context:
>> http://n2.nabble.com/2-1-0-Final-Windows-Installer-tp4023684p4034013.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
