[mapguide-internals] Re: FeatureSet xml serialization issues (RE: SELECTFEATURES via mapagent and null values)
Jackie Ng jumpinjackie at gmail.com
Thu Apr 8 21:41:54 EDT 2010
An empty string (a string property whose value is "") is different to a null
string (a string property without an actual assigned value).
If by your suggestion that null property values are coerced into empty
strings when serializing, then empty string values (which may be legitimate)
will be misinterpreted as null string values when serialized.
- Jackie
View this message in context: http://n2.nabble.com/SELECTFEATURES-via-mapagent-and-null-values-tp1822076p4874876.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
