[mapguide-internals] PATCH: MgNullableProperty XML serialization fix
Jason Birch jason at jasonbirch.com
Tue Apr 13 21:34:24 EDT 2010
Is there JSON output for this? If so, how do you handle nulls for JSON
output?  I think there may be a native NULL type?
On 2010-04-13, Jackie Ng <jumpinjackie at gmail.com> wrote:
> If SELECTFEATURES is the only means through which this format can be
> consumed, then I think an in-place update is fine, seeing (as you already
> know) the operation hasn't worked properly in over 1.5 years.
> - Jackie
> http://n2.nabble.com/PATCH-MgNullableProperty-XML-serialization-fix-tp4896341p4899154.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
