[mapguide-internals] cross-compiling CS-Map 64-bit
Jackie Ng
jumpinjackie at gmail.com
Tue Aug 3 09:54:21 EDT 2010
Hi All,
I am having an issue compiling CS-Map with the 64-bit Visual C++
cross-compiler. The problem is that the "Compiler" project has a post-build
event which actually runs the compiled executable (CS_Comp.exe).
If I am cross-compiling CS-Map from a 32-bit environment, this will
obviously fail because CS_Comp.exe will be a 64-bit binary.
What I was wondering is if I can get away with explicitly building the
"Compiler" project as 32-bit while building the rest as 64-bit. The purpose
of CS_Comp.exe is just to compile these CS dictionaries and isn't used by
any other MapGuide component. Am I correct in saying this?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/cross-compiling-CS-Map-64-bit-tp5368454p5368454.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
