[mapguide-internals] Re: The coordinate system initialization failed
Trevor Wekel trevor_wekel at otxsystems.com
Tue Jun 8 23:30:26 EDT 2010
Hi Edu,
I did some checking into the postgresql libraries on Ubuntu 9.10.  Ubuntu 9.10 uses postgresql 8.3 or 8.4.  The FDO Provider was compiled on CentOS 5.4 against postgresql 8.1.  It is possible that the version difference in the libraries on Ubuntu 9.10 may be causing the failure.  If this is the case, then we may not be able to support postgresql on Ubuntu without native Ubuntu compilation.  That would be disappointing.
To the list - has anyone tried using the PostgreSQL or PostGIS providers on CentOS 5.4?
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Eduardo Sereno
Sent: June 8, 2010 7:45 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: The coordinate system initialization failed
I have done ldd -r to libPostGISProvider-3.5.0.so and
libFdoPostgreSQL-3.5.0.so and none report any problem.
I am no using Oracle... im using postgres is there any relation????
Best
Edu
View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5156297.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
