[mapguide-internals] Supporting PHP 5.3
Jason Birch jason at jasonbirch.com
Fri Mar 19 19:23:42 EDT 2010
These changes are fairly limited in scope and (will be) well
documented. I have no problems with this.
Are you looking at 2.2 or 2.3 for this?
On 2010-03-19, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> Hi All,
> In updating to support PHP 5.3 I have been playing in the sandbox/adsk/2.2gp
> code base and have run into some API issues that are a result of the changes
> to how exceptions work in PHP 5.3.
> In particular all exception classes must be derived from the PHP Exception
> base class.
> Changing this causes more issues - namely a side effect of having to have
> the PHP Exception class as the base class is that it becomes the base class
> of MgObject which almost everything in our API derives from.
> This causes an API naming conflict with existing MapGuide APIs because PHP
> is case insensitive  - ie: getMessage() and GetMessage() are the same in the
> PHP world.
> The PHP Exception class is defined as follows: (These are the APIs with
> which we can have conflicts with)
> const static zend_function_entry default_exception_functions[] = {
>                 ZEND_ME(exception, __clone, NULL,
> ZEND_ACC_PRIVATE|ZEND_ACC_FINAL)
>                 ZEND_ME(exception, __construct,
> arginfo_exception___construct, ZEND_ACC_PUBLIC)
>                 ZEND_ME(exception, getMessage, NULL,
> ZEND_ACC_PUBLIC|ZEND_ACC_FINAL)
>                 ZEND_ME(exception, getCode, NULL,
>                 ZEND_ME(exception, getFile, NULL,
>                 ZEND_ME(exception, getLine, NULL,
>                 ZEND_ME(exception, getTrace, NULL,
>                 ZEND_ME(exception, getPrevious, NULL,
>                 ZEND_ME(exception, getTraceAsString, NULL,
>                 ZEND_ME(exception, __toString, NULL, 0)
>                 {NULL, NULL, NULL}
> Of the above APIs only the getMessage() and getCode() APIs are currently
> causing conflicts with MapGuide APIs.
> What I have had to do in order to get around this is to change some of the
> existing MapGuide APIs so that they no longer conflict with PHP. The changes
> are as follows:
> MgException class changes:
> Change GetMessage() to GetExceptionMessage()
> MgResources class changes:
> Change GetMessage() to GetResourceMessage()
> MgCoodinateSystem class changes:
> Change GetCode() to GetCsCode()
> I also changed SetCode() to SetCsCode() for consistency.
> MgCoodinateSystemDatum class changes:
> MgCoodinateSystemEllipsoid class changes:
> MgWebInvokeScriptCommand class changes:
> Change GetCode() to GetScriptCode()
> I also changed SetCode() to SetScriptCode() for consistency.
> Of course with these changes any existing .NET, Java or PHP applications
> would also have to be updated to use these renamed APIs.
> I would like to get community feedback on this now in order to make any
> needed changes before this is officially adopted into the trunk code stream.
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
