[mapguide-internals] trunk rev 4670 fails on Sheboygan Map with FDO Exception
Trevor Wekel trevor_wekel at otxsystems.com
Sat Mar 20 06:17:38 EDT 2010
Hi UV,
Is this also reproducible with a release build?  The first thing that comes to mind is that a debug build of FDO might help.  This was not really necessary in MGOS 2.1 but perhaps something has changed.  Anyway, I should be able to do some build testing on Tuesday so see if I can reproduce what you are seeing.  I actually started doing this Thursday night but then I got pre-empted Friday morning.
I will be replacing & RMAing some dead disk on the VMware cluster hosting the MapGuide 2.2 builds Monday.  I doubt I will be able get to the build until Tuesday.  Three disk failures in a month.  Yeesh.  Good thing the disk array has hot spares.
Regards,
Trevor Wekel
http://www.otxsystems.com
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: March 18, 2010 1:19 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] trunk rev 4670 fails on Sheboygan Map with FDO Exception
I am attempting to get a debug build of trunk rev 4670 working
I tried to run it with the FDO 3.5 RC1 SDK as well as with trunk version
5389 on windows.
trying to render any image for the sheboygan map (or any other) the code
on line 56 fires an FDO exception trying to do:
ExpressionHelper .cpp:56:     userDefinedFunctions->Add(funcIf);
in the log we find
<2010-03-17T20:18:26>     7680    Ajax Viewer    127.0.0.1
 Error: Failed to stylize layer: (ANY LAYER)
        An exception occurred in FDO component.
        Item index out of bounds.
what is going wrong here?
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
