[mapguide-internals] Re: 32 bit installer on build machine
Trevor Wekel trevor_wekel at otxsystems.com
Mon Mar 22 18:41:30 EDT 2010
Yep.  Figured some of that out already...
call build.bat -source=%INSTALLROOT% -version=2.2.0.%REVISION% -name=MapGuideOpenSource-2.2.0.%REVISION%-Beta1 -title="MapGuide Open Source 2.2 Beta 1"
So I think I will hack up updateversion.vbs script to simply take the build number on the command line.  "svn info" doesn't work with export.  Then we should be all set.
Do you want me to post the installer on OSGeo downloads so you can try it out.  So far, Apache/PHP and IIS/.Net both seem to be working.
Thanks Jason (and Jackie),
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: March 22, 2010 4:27 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Re: 32 bit installer on build machine
Lol...
In the MgDev folder, there's a file called UpdateVersion.vbs that goes
through and updates the header and resource files that hold the version
numbers.  This script relies on the commandline svn tools being installed,
must be run in an SVN checkout area. and may not contain all the files
required for 2.2.  Not sure whether it's better to continue using this, or
to re-write in Perl/PHP.
There are other commandline options to the installer's build.bat that could
be useful.  Here's what I used for the final build:
call build.bat -a=build -version=2.1.0.4283
-name=MapGuideOpenSource-2.1.0.4283-Final -title="MapGuide Open Source
2.1.0"
These are carried through to the installer in most cases. I believe that
Jackie recently checked in some other useful changes, such as parameterizing
the server service version instead of hard-coding it as a string.
Jason
More information about the mapguide-internals mailing list
