[mapguide-internals] Re: 32 bit installer on build machine
Trevor Wekel trevor_wekel at otxsystems.com
Mon Mar 22 19:46:51 EDT 2010
Ok.  I should be able to do a properly branded build tonight.
Trevor Wekel
http://www.otxsystems.com
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: March 22, 2010 5:03 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Re: 32 bit installer on build machine
Sure, could do.
We should make sure to confirm with external projects (Fusion, FDO, CS-Map)
that we're referencing the correct revisions before we go beta.
Jason
On 22 March 2010 15:41, Trevor Wekel wrote:
> Yep.  Figured some of that out already...
> call build.bat -source=%INSTALLROOT% -version=2.2.0.%REVISION%
> -name=MapGuideOpenSource-2.2.0.%REVISION%-Beta1 -title="MapGuide Open Source
> 2.2 Beta 1"
> So I think I will hack up updateversion.vbs script to simply take the build
> number on the command line.  "svn info" doesn't work with export.  Then we
> should be all set.
> Do you want me to post the installer on OSGeo downloads so you can try it
> out.  So far, Apache/PHP and IIS/.Net both seem to be working.
> Thanks Jason (and Jackie),
> Trevor
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
