[mapguide-internals] Re: 32 bit installer on build machine
Mike Adair madair at dmsolutions.ca
Tue Mar 23 10:44:31 EDT 2010
I'm working on the trunk but I will be doing a merge to the 2.0 branch
for the release,.  I will have an RC ready this week.
Mike
Paul Spencer wrote:
> Mike is very close to finalizing the 2.0 version of Fusion, I don't know if he is working from trunk or from the 2.0 branch but I would like it to be from the branch if it isn't already.  I'll discuss with Mike tomorrow and make sure that's good with him.
> Cheers
> Paul
> On 2010-03-22, at 7:03 PM, Jason Birch wrote:
>> Sure, could do.
>> We should make sure to confirm with external projects (Fusion, FDO, CS-Map)
>> that we're referencing the correct revisions before we go beta.
>> Jason
>> On 22 March 2010 15:41, Trevor Wekel wrote:
>>> Yep.  Figured some of that out already...
>>> call build.bat -source=%INSTALLROOT% -version=2.2.0.%REVISION%
>>> -name=MapGuideOpenSource-2.2.0.%REVISION%-Beta1 -title="MapGuide Open Source
>>> 2.2 Beta 1"
>>> So I think I will hack up updateversion.vbs script to simply take the build
>>> number on the command line.  "svn info" doesn't work with export.  Then we
>>> should be all set.
>>> Do you want me to post the installer on OSGeo downloads so you can try it
>>> out.  So far, Apache/PHP and IIS/.Net both seem to be working.
>>> Thanks Jason (and Jackie),
>>> Trevor
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://research.dmsolutions.ca/
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
More information about the mapguide-internals mailing list
