[mapguide-internals] MapGuide 2.2 Beta Release Readiness
Martin Morrison martin.morrison at edsi.com
Tue Mar 23 22:11:51 EDT 2010
Windows....
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel [trevor_wekel at otxsystems.com]
Sent: Tuesday, March 23, 2010 9:39 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide 2.2 Beta Release Readiness
Hi Martin,
Are you using Windows or Linux?
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: March 23, 2010 7:06 PM
NO!!!!!!!
Do the 64 bit Apache...<flamesuit on> that way some of us can have nice stable fast webservers...<flamesuit off>
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch [jason at jasonbirch.com]
Sent: Tuesday, March 23, 2010 7:35 PM
Subject: Re: [mapguide-internals] MapGuide 2.2 Beta Release Readiness
That sounds like a plan. Your idea of trivial and mine are likely orders of
magnitude different though :)  I don't have any problems bundling up PHP,
but actually compiling it is a different question entirely... are the
changes you had to make actually in the sandbox, and can they be ported to
trunk?
I personally think we should remain with the ISAPI module for the MapAgent
as long as it compiles in 64bit.
If we can get this together for IIS, I'm still of the mind that 64bit Apache
option is likely not worth the trouble.  Oh, and that perhaps we should
restrict 64bit IIS to IIS7+?
Jason
On 23 March 2010 11:44, Bruce Dechant wrote:
> Going forward PHP only officially supports FastCGI and has dropped ISAPI
> support - for both 32bit and 64bit.
> However, the code is still there and only required a trivial tweaking to
> get the 64bit ISAPI module built so we could continue to use the ISAPI
> module for 2.2 and move to FastCGI for 2.3
> Thanks,
> Bruce
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
