[mapguide-internals] Re: 32 bit installer on build machine
UV uvwild at googlemail.com
Tue Mar 23 22:58:17 EDT 2010
Why is there no README file in the Installer top level directory with
this information?
I could never find any info on how to get it to work so I gave up using
this and had to install manually!
Documentation is essential! Whats the point of writing code nobody else
can use?
Jackie Ng wrote:
> Hi Trevor,
> The build.bat has an -a=generate option that rebuilds the wxs files from
> scratch. The installer uses MgDev\Release as the default directory from
> where Paraffin will generate its file list.
> Because the MG output directory does not initially have the Apache, PHP and
> Tomcat binaries, these need to be copied over. The -a=prepare option
> fulfills this purpose.
> I usually have paraffin.exe inside the Installer root directory.
> After a successful run of MgDev\build.bat w/ default settings, I do the
> following from the Installer directory:
> build.bat -a=prepare
> build.bat -a=generate
> build.bat
> - Jackie
More information about the mapguide-internals mailing list
