[mapguide-internals] Location of httpd.conf for Windows/Apache
Dave Wilson dave.wilson at autodesk.com
Tue Mar 30 16:41:27 EDT 2010
I logged a defect regarding the workers.properties file for connecting to Tomcat via Apache. You may want to see if this is an issue in OSGeo as well:
The workers.properties file found in the Apache2/conf folder contains 3 settings that were deprecated in version 1.2.16
worker.worker1.cachesize
worker.worker1.cache_timeout
worker.worker1.recycle_timeout
are all deprecated. There are newer settings discussed here:
http://tomcat.apache.org/connectors-doc/reference/workers.html
The above settings are useless and in fact cachesize is flagged explicitly not to be used "Do not use cachesize with values higher then 1 on Apache 2.x prefork or Apache 1.3.x!"
We should review our worker settings and determine what the corrrect settings should be. For example lbfactor does not seem to apply in our configuration.
Various errors appear on the mod_jk.log as a result of the settings. They appear to cause connection issues with Tomcat which may be causing failures.
So far the only settings I think we need are as follows:
# Define 1 real worker using ajp13
worker.list=worker1
# Set properties for worker1 (ajp13)
worker.worker1.type=ajp13
worker.worker1.host=localhost
worker.worker1.port=8009
worker.worker1.socket_keepalive=1
Regards,
Dave
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Tuesday, March 30, 2010 2:36 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Location of httpd.conf for Windows/Apache
Thanks Jason.  The changes are mostly for Apache/Tomcat.  I fully expect the change set to be different on Windows.  The Windows conf file should be more up to date.  Once I've got the Linux build going, I will create a ticket for the Installer.
Regards,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: March 30, 2010 2:34 PM
Subject: Re: [mapguide-internals] Location of httpd.conf for Windows/Apache
Look in trunk/installer/support/web/apache2/conf.
There is a custom action under installer/custom/apache_actions which, I believe, replaces templated values in this file.
If these changes are for the tomcat fixes and mod_rewrite stuff you checked in a while back, it's probably a good thing, but I'd like to see them committed against a ticket in the installer component to track them.
Jason
On 2010-03-30, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hey guys (mostly Jackie and Jason),
> I made some changes to httpd.conf on Linux that may be good for
> Windows as well.  Do you know where/how httpd.conf gets generated for
> the Windows installer?
> Thanks,
> Trevor
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
