[mapguide-internals] MapGuide OSM Sample Project
Martin Morrison martin.morrison at edsi.com
Wed Mar 31 13:35:04 EDT 2010
For disconnected users...
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Wednesday, March 31, 2010 12:45 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide OSM Sample Project
Hi Zack,
Why should we be putting effort into demonstrating something (static map of the world) which Google Maps already does better than we can ever hope to do with OSM data?
Traian
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, March 31, 2010 9:46 AM
Subject: Re: [mapguide-internals] MapGuide OSM Sample Project
don't we have SLD which we could consume?
if FDO was transparent, FDO would not be an issue
we should be domonstrating the best free global dataset
with MG doing the rendering, anything less is a cop out
for now simple php scripts can overcome the FDO polution
so i reckon the first step, is to take a standards based SLD
and import it into a mapguide map
we can have a php script to overcome specific FDO class name
issues between FDO providers
then we have a really good dataset/map to reference
OSM data is already available FDO readable, lets work with that,
tho SQLlite i think is the best :)
z
On 28 March 2010 08:50, Traian Stanev <traian.stanev at autodesk.com> wrote:
> I agree that OSM is perhaps not very relevant for the average MapGuide user (which is partly why I gave up :)). Maybe if someone wanted to use MapGuide's RenderingService as a pre-rendering backend for large scale map tiles, or to visualize OSM itself... But there are already dedicated renderers for OSM which produce similar quality to MapGuide, and there must be a way to directly consume their output as a backdrop in a MapGuide map -- that approach would be less effort.
> Traian
> P.S. By the way, a cool use for OSM is an offline maps application for Android, as shown here http://www.mapdroyd.com/
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Saturday, March 27, 2010 1:01 PM
> Someone could pipe it through FME (which supports all these formats) a
> bit more easily :) Would have to somehow automate the process though,
> so I guess licensing may be a concern. There are also some commandline
> tools (like osm2pgsql) that could help get the data into a format we
> can use with FDO. Sure would be nice to be able to start from SQLite
> though.
> Not sure of the value as a sample dataset. Much of MapGuide's value
> proposition is in its server-side capabilities, and without structured
> data (assessment, zoning, etc) this may be hard to showcase. OSM is a
> greatbackdrop though. Would be great if we could take a region with
> extensive open geodata (DC? Vancouver?) and bundle/maintain a
> high-intelligence local sample using both OSM and local gov't data.
> Jason
> On 2010-03-27, Traian Stanev <traian.stanev at autodesk.com> wrote:
>> A while back I started on some code to convert OSM data to FDO. I didn't
>> finish coding it though, but I did get to the stage of parsing the XML and
>> inserting a desired subset of attributes from it into a temporary SQLite
>> database, which my plan was to convert to FDO SQLite format using a second
>> conversion step (which would further classify the raw topology data, so you
>> get a table for streets, a table for buildings, etc.)
>> One piece of advice -- if you ever do this, use a custom stream reader which
>> reads directly from the ZIP file using zlib and passes the decoded memory
>> stream to your XML parser (I used libxml++, a lot better than Xerces IMO).
>> This way you don't have to unzip the whole thing, and use up 120 Gigs on
>> your drive.
>> Traian
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
>> Wekel
>> Sent: Saturday, March 27, 2010 11:30 AM
>> Hi Zac,
>> I just did a bit of a pan around www.openstreetmap.org.  Oh boy.
>> - World wide coverage
>> - Multiple languages (English, Russian, Arabic, Mandarin, other..)
>> - Street level detail for Canada, USA, Europe, Russia, and more
>> - Points of interest, building footprints in some area
>> - The full dataset in OSM XML is a 13GB bzip compressed image
>> The data is also covered under a non-restrictive license.
>> Great suggestion.  This is an impressive dataset.  Anyone want to download
>> it and convert it to SDF?  I wonder if download.osgeo.org would let us post
>> the whole dataset?
>> Regards,
>> Trevor
>> Sent: March 26, 2010 9:54 AM
>> Subject: [mapguide-internals] MapGuide OSM Sample Project
>> Hey everyone,
>> I think it's high time we have a global OSM mapguide sample
>> http://code.google.com/p/mapguide-osm
>> who's interested in helping author a MGP for sample based off OSM data?
>> z
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
