[mapguide-internals] Clarifying the 64-bit support
Bruce Dechant bruce.dechant at autodesk.com
Fri May 7 11:36:30 EDT 2010
This was on Windows only - I didn't try Linux.
I think more work is needed for 64bit Linux.
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: Friday, May 07, 2010 9:35 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Clarifying the 64-bit support
>From the work I did in the Web Extension it should work with 64bit :)
When I built the source myself and configured it I was able to use Apache/PHP, Apache/Tomcat(Java) and IIS/.NET.
Thanks,
Bruce
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, May 06, 2010 8:16 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Clarifying the 64-bit support
Hi All,
I'd like some clarifications as to the 64-bit support in MGOS 2.2
I understand the server will be fully 64-bit, but what about the web
extensions and managed APIs (PHP/Java/.net)?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Clarifying-the-64-bit-support-tp5017541p5017541.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
