[mapguide-internals] svn checkout/update timeout
Rohit Razdan rrrazdan at gmail.com
Mon May 10 10:17:30 EDT 2010
On Mon, May 10, 2010 at 2:50 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi All,
> I've been trying to do a svn update on a pretty stale working copy from one
> of my work machines. But I've keep getting the following error message:
> Error: REPORT of '/mapguide/!svn/vcc/default': Could not read response body:
> Error: connection was closed by server (http://svn.osgeo.org)
> Has anybody else experienced such issues like this? I can do large
> checkouts/updates just fine from my home machine.
Yes I have experienced this same problem, with TortoiseSVN on a
Windows 7 machine. Interestingly I didn't experience this with the
code in the branch/2.1 structure but only in the trunk structure.
Checkout worked smoothly on ubuntu 9.10 as well, but again I was
checking out the branch/2.1 and not the trunk. Preliminary googling
suggests that this could be a problem with the amount of temp space on
the svn server. Might be a good idea to check with the OSGEO guys, if
they experience something like this on other projects as well.
Rohit
More information about the mapguide-internals mailing list
