[mapguide-internals] MapGuide 2.2 beta crashes
Zac Spitzer zac.spitzer at gmail.com
Sat Oct 16 23:14:58 EDT 2010
I can't see it here, shall i file this?
http://trac.osgeo.org/mapguide/query?status=new&status=assigned&status=reopened&group=component&order=priority
the call is resourceExists()
On Sun, Oct 17, 2010 at 10:21 AM, Jason Birch <jason at jasonbirch.com> wrote:
> It can be avoided by testing if the resource exists first using a call
> that was introduced in (I think) 2.1. Can't remember its name off
> hand. Fusion was updated to use it at the time; I only remember this
> because I back-ported the changes to my local 1.1 code.
> On 2010-10-15, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> Is there task for that corruption problem?
>> On Sat, Oct 16, 2010 at 4:21 AM, Gabriele Monfardini
>> <gabrimonfa at gmail.com> wrote:
>>> Dear Jason,
>>> for layers I usually use
>>> $layerCollection = $map->GetLayers();
>>> and tests
>>> $layerCollection->Contains($layerName)
>>>> There's a nasty memory
>>>> corruption problem if you just try to catch a failed
>>>> getresourcecontent call
>>> Good (and scary) to know
>>> Regards,
>>> Gabriele Monfardini
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
