[mapguide-internals] PATCH: Ticket 1493 "Resize window caused dynamic layers disappear if the map with Base layers in Chrome/Safari"
Arthur Liu arthur.liu at autodesk.com
Mon Oct 25 04:25:56 EDT 2010
Hi Ted,
This patch looks good. I have submitted the patch on your behalf.
Thanks,
Arthur
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ted Yang
Sent: Friday, October 22, 2010 5:45 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] PATCH: Ticket 1493 "Resize window caused dynamic layers disappear if the map with Base layers in Chrome/Safari"
Hi all,
Would you please help to review ticket: https://trac.osgeo.org/mapguide/ticket/1493 and the patch attached to it?
It's about fixing a bug in ajaxviewer that when a map with base layer and dynamic layer works incorrect in Chrome/Safari.
When resize the window, the image for the dynamic layers will be invisible.
The solution is to find the place where should make the map image layer visible.
Best Wishes,
Ted Yang (Yuanyuan Yang)
Reeses,Tel: (8621)3866-4595
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
