[mapguide-internals] MapGuide 2.2 RC1 build in two weeks
Mike Adair madair at dmsolutions.ca
Fri Sep 10 14:45:23 EDT 2010
  Hi Trevor,
Sorry I forgot about that and vaguely remember seeing that.  I've been
doing some bug fixes in trunk so I'll do my best to merge from trunk
into that branch then.  As Jason said there's probably no harm in having
the QuickPlot widget there.
Mike
On 9/10/2010 1:57 PM, Trevor Wekel wrote:
> Hi Mike,
> You're probably going to hate me...  Paul let me create the Fusion 2.2 branch a couple of months ago so that I could get an interim build out the door for MapGuide.
> http://trac.osgeo.org/fusion/log/branches/fusion-2.2
> Is there anything we need to port from trunk?  I suppose we could delete the branch and recreate it from trunk but I'm not sure the new QuickPlot feature is supposed to go into 2.2.  That's a MapGuide 2.3 feature.
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: September 10, 2010 11:48 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] MapGuide 2.2 RC1 build in two weeks
>    Trevor,
> FYI, I'll be creating a Fusion v2.2 branch from trunk either later today
> or early next week that can be used for this release of MGOS.
> Mike
> On 9/10/2010 12:26 PM, Trevor Wekel wrote:
>> Hi everyone,
>> I am going to do some work on the MapGuide 2.2 RC1 build over the next couple of weeks with the target of releasing the MapGuide 2.2 RC1 build by September 24th.  In my opinion, these are the critical items holding up the build:
>> 1. FDO 3.5 RC2(?) build
>> 2. The entire Java Web Extensions API leaks objects (mapguide-internals discussion)
>> 3. http://trac.osgeo.org/mapguide/ticket/1423 Linux std::string not thread safe
>> 4. http://trac.osgeo.org/mapguide/ticket/1382 Undefined symbols in FDO PostGIS e FDO PostgreSQL/PostGIS providers
>> 5. Upgrade 32 bit installer binaries to Apache 2.2.15 (currently 2.2.11)
>> 6. Upgrade 32 bit and 64 bit installer binaries to PHP 5.3.3 (assuming VC9 thread-safe binaries are available)
>> Is there anything else we need to put into the RC1 build?  I will concentrate my efforts on items 1 to 4 and could use some help with the last two.
>> Thanks!
>> Trevor
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
    Michael Adair
    Senior Software Architect
    DM Solutions Group Inc.
    Office: (613) 565-5056 x26
    http://www.dmsolutions.ca
    http://research.dmsolutions.ca
More information about the mapguide-internals mailing list
