[mapguide-internals] Re: Create TRAC ticket privileges
Jackie Ng jumpinjackie at gmail.com
Sat Apr 9 01:01:59 EDT 2011
Your osgeo user id should be global across all trac instances. So see if you
can create one on the OSGeo trac instance (http://trac.osgeo.org/osgeo)
If you can, then use that ticket to describe this problem.
As an aside, I notice through nabble that this email is yet to be accepted.
Could possibly be related?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Create-TRAC-ticket-privileges-tp6255358p6256171.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
