[mapguide-internals] Please review http://trac.osgeo.org/mapguide/attachment/ticket/1779/Fix1779.patch
Christine Bao Christine.Bao at autodesk.com
Mon Aug 15 02:49:57 EDT 2011
Hi Zac,
     Thank you for your comments.
     The wiki http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni is updated, adding DBEvironment section for ServerConfig.ini.
     However I am afraid it's hard to directly tell user how to fix load package issue in site administrator. DB_Error_*** can be caused by many reasons, and this ticket is just one case. It may be helpful to add the new settings in help document and give user reference document to learn about DB environment setting to know which size is better for them. The benefit of this fixing is to move hard-coded setting to configurable setting, thus user can change configuration according to their requirements.
Thanks & regards,
Christine
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, August 15, 2011 2:19 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Please review http://trac.osgeo.org/mapguide/attachment/ticket/1779/Fix1779.patch
could the error message in the site administrator be updated to indicate how to fix the problem via these new configuration parameters?
once this is implemented, the wiki would need updating as well http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni
otherwise, looks great... it's really good to expose some of these hardwired settings as configurable items
z
On Mon, Aug 15, 2011 at 4:06 PM, Christine Bao <Christine.Bao at autodesk.com> wrote:
> Hi all,
>     Please review http://trac.osgeo.org/mapguide/attachment/ticket/1779/Fix1779.patch for fixing ticket http://trac.osgeo.org/mapguide/ticket/1779.
> Thanks & regards,
> Christine
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
