[mapguide-internals] MapGuide RC3 Delayed - Fusion Map tips are broken
Trevor Wekel trevor_wekel at otxsystems.com
Mon Feb 7 09:57:29 EST 2011
Great!!! Thank you Mike.  I had to get back to some other work and ran out of time to investigate further.
I've also started looking into Cruise Control for build automation.  Sometime in the future, the combination of Cruise Control + Ant + JUnit + Selenium could be a viable way to perform end to end build validation on multiple browsers and platforms.  Selenium can capture UI interaction and generate Java tests which can then be run under JUnit.  From what I can tell, Cruise Control has built in support for running and reporting on JUnit test cases.  MapGuide is a big app to test and a end-to-end automation stack will be a bit of an undertaking.
http://cruisecontrol.sourceforge.net/
http://seleniumhq.org/
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Michael Adair
Sent: February 7, 2011 7:36 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] MapGuide RC3 Delayed - Fusion Map tips are broken
Trevor,
I will have a look at that today.
Mike
On 06/02/2011 11:19 AM, Trevor Wekel wrote:
> Hello list,
> After spending most of the last few days reconfiguring the build infrastructure after hardware failure and building MapGuide 2.2:
> - Windows 32 bit
> - Windows 64 bit
> - CentOS 5 32 bit
> - Ubuntu 9 32 bit (based on CentOS 5 bins)
> I am "disappointed" to report that initial validation of the build using the sample Sheboygan map was not successful.  The Fusion tooltips seem to be broken.  Since tooltips are somewhat important, the build has been put on hold until someone (not me) had had a chance to fix the issue.
> http://trac.osgeo.org/fusion/ticket/433 Map tips are broken in branches/2.2
> Regards,
> Trevor
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
