[mapguide-internals] Re: Review patch request: Add a new command "MapTip" for Web layout to disable/enable map tooltips
Bruce Dechant bruce.dechant at autodesk.com
Fri Jul 29 11:22:06 EDT 2011
Buddy,
Schema changes require an RFC so you did the right thing in creating one.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Buddy Hu
Sent: Friday, July 29, 2011 8:05 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Re: Review patch request: Add a new command "MapTip" for Web layout to disable/enable map tooltips
Thanks Jackie for your question!
I don't know whether a one line change of schema require an RFC. I compose an RFC https://trac.osgeo.org/mapguide/wiki/MapGuideRfc120 for you review, in case we indeed need it. If we don't need it, I will remove the RFC then.
Please give me your comments.
Regards,
Buddy
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, July 29, 2011 6:10 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Review patch request: Add a new command "MapTip" for Web layout to disable/enable map tooltips
Doesn't schema revisions in general require an RFC?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Review-patch-request-Add-a-new-command-MapTip-for-Web-layout-to-disable-enable-map-tooltips-tp6632919p6632967.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
