[mapguide-internals] RE: Motion: Commit rights for Mars Wu andSpark Liu
Jonathan Rizzo jrizzo at Langan.com
Fri Jul 29 11:20:03 EDT 2011
Minor detail, but I was reading over the coding standards and I found an
incorrect statement about Try-Catch Statements:
"A try-catch statement may also be followed by finally which is always
executed (unless an exception is thrown in the body of an executed
catch)."
In fact, finally WILL execute even if an exception is thrown in the body
of an executed catch.  I use this technique quite often to "clean up" in
the event of an exception but still pass the exception up the stack.
A minor point, I know, but I thought I should point it out.
Jon
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Thursday, July 28, 2011 1:20 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: Motion: Commit rights for Mars Wu
andSpark Liu
As long as they have read and understood the coding standards
(https://trac.osgeo.org/mapguide/wiki/MapGuideCodingStandards) then I
support this.
Walt
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Thursday, July 28, 2011 11:56 AM
To: MapGuide Internals Mail List (mapguide-internals at lists.osgeo.org)
Subject: [mapguide-internals] Motion: Commit rights for Mars Wu and
Spark Liu
Hi All,
I'd like to propose that we grant subversion commit rights for the
MapGuide vault to Mars Wu and Spark Liu.
They are Autodesk developers working in Shanghai, and have made numerous
defect fixes and enhancements to the code base over the last few years.
Mars Wu has worked on MGOS for more than 2 years. Here is a summary of
the tickets, changesets and RFC he has done:
RFC:
-          MapGuide RFC 96 - QuickPlot solution for both Ajax and Fusion
viewers<http://trac.osgeo.org/mapguide/wiki/MapGuideRfc96>
Tickets:
-          #1412<http://trac.osgeo.org/mapguide/ticket/1412> Implement
RFC 96 - Quick Plot solution for
fusion<http://trac.osgeo.org/mapguide/ticket/1412>
-          #1414<http://trac.osgeo.org/mapguide/ticket/1414> Implement
ajax<http://trac.osgeo.org/mapguide/ticket/1414>
-          #1435<http://trac.osgeo.org/mapguide/ticket/1435> IE8: Map
context menu doesn't work after Quick Plot is
invoked<http://trac.osgeo.org/mapguide/ticket/1435>
-          #1443<http://trac.osgeo.org/mapguide/ticket/1443>
MgProxyFeatureService::GetCapabilities is using a fixed api version
1.0.0<http://trac.osgeo.org/mapguide/ticket/1443>
-          #1589<http://trac.osgeo.org/mapguide/ticket/1589> Ajax Quick
Plot: Capture box cannot move or rotate when base layers
exist<http://trac.osgeo.org/mapguide/ticket/1589>
-          #1757<http://trac.osgeo.org/mapguide/ticket/1757> Quick Ploat
cannot generate map picture in some non-English
locale<http://trac.osgeo.org/mapguide/ticket/1757>
-          #1521<http://trac.osgeo.org/mapguide/ticket/1521> Use mouse
wheel to zoom map in the "Digitize"
process<http://trac.osgeo.org/mapguide/ticket/1521>
-          #1539<http://trac.osgeo.org/mapguide/ticket/1539> Script
error when closing IE window / tab with the Quick Plot preview dialog
open in Ajax viewer<http://trac.osgeo.org/mapguide/ticket/1539>
-          #1546<http://trac.osgeo.org/mapguide/ticket/1546> Ajax quick
plot enhancements: mouse cursor and event
controlling<http://trac.osgeo.org/mapguide/ticket/1546>
-          #1585<http://trac.osgeo.org/mapguide/ticket/1585> Zoom
Rectange doesn't work properly in Ajax
viewer<http://trac.osgeo.org/mapguide/ticket/1585>
Changesets:
-          6012<http://trac.osgeo.org/mapguide/changeset/6012>
-          6010<http://trac.osgeo.org/mapguide/changeset/6010>
-          5509<http://trac.osgeo.org/mapguide/changeset/5509>
-          5507<http://trac.osgeo.org/mapguide/changeset/5507>
-          5501<http://trac.osgeo.org/mapguide/changeset/5501>
-          5430<http://trac.osgeo.org/mapguide/changeset/5430>
-          5512<http://trac.osgeo.org/mapguide/changeset/5512>
-          5411<http://trac.osgeo.org/mapguide/changeset/5411>
-          5394<http://trac.osgeo.org/mapguide/changeset/5394>
-          5152<http://trac.osgeo.org/mapguide/changeset/5152>
-          5132<http://trac.osgeo.org/mapguide/changeset/5132>
-          5098<http://trac.osgeo.org/mapguide/changeset/5098>
-          5097<http://trac.osgeo.org/mapguide/changeset/5097>
-          5095<http://trac.osgeo.org/mapguide/changeset/5095>
-          4091<http://trac.osgeo.org/mapguide/changeset/4091>
Spark has worked on MGOS for more than 2 years. Here is a summary of the
RFC:
-          108 Support
Watermark<http://trac.osgeo.org/mapguide/wiki/MapGuideRfc108>
Tickets:
-          1514 Ctrl+Click can't end digitize LineString in Chrome on
Windows<http://trac.osgeo.org/mapguide/ticket/1514>
-          1527 Rendering fails if the map references to a not-exist
resource<http://trac.osgeo.org/mapguide/ticket/1527>
-          1553 Ctrl+Click at first when "selecting polygon" shows error
message in Safari / Chrome<http://trac.osgeo.org/mapguide/ticket/1553>
-          1605 There is no Serializable attribute for C# wrapper of any
exception class which make the exception can't get across the
AppDomain<http://trac.osgeo.org/mapguide/ticket/1605>
-          1728 Fetch size is not set when using command even when
DataCacheSize configuration is
set<http://trac.osgeo.org/mapguide/ticket/1728>
-          1752 Misuse column name instead of column index during data
reader's serialization<http://trac.osgeo.org/mapguide/ticket/1752>
-          1756 ServerFeatureService.DescribeSchemaAsXml will throw
exception when geometry property is inherited from base
class<http://trac.osgeo.org/mapguide/ticket/1756>
-          1762 Connect always shows "Cannot parse XML document whose
stream is at end-of-file." when setting
configuration<http://trac.osgeo.org/mapguide/ticket/1762>
Changesets:
-          6011<http://trac.osgeo.org/mapguide/changeset/6011>
-          5999<http://trac.osgeo.org/mapguide/changeset/5999>
-          5988<http://trac.osgeo.org/mapguide/changeset/5988>
-          5949<http://trac.osgeo.org/mapguide/changeset/5949>
-          5557<http://trac.osgeo.org/mapguide/changeset/5557>
-          5556<http://trac.osgeo.org/mapguide/changeset/5556>
-          5458<http://trac.osgeo.org/mapguide/changeset/5458>
-          5444<http://trac.osgeo.org/mapguide/changeset/5444>
-          5393<http://trac.osgeo.org/mapguide/changeset/5393>
-          5367<http://trac.osgeo.org/mapguide/changeset/5367>
-          5366<http://trac.osgeo.org/mapguide/changeset/5366>
-          5365<http://trac.osgeo.org/mapguide/changeset/5365>
-          5302<http://trac.osgeo.org/mapguide/changeset/5302>
-          5290<http://trac.osgeo.org/mapguide/changeset/5290>
-          5237<http://trac.osgeo.org/mapguide/changeset/5237>
-          5220<http://trac.osgeo.org/mapguide/changeset/5220>
-          5168<http://trac.osgeo.org/mapguide/changeset/5168>
-          5139<http://trac.osgeo.org/mapguide/changeset/5139>
-          4461<http://trac.osgeo.org/mapguide/changeset/4461>
I would like to motion for a vote on giving Mars Wu and Spark Liu commit
rights to the MapGuide vault.
+1 Bruce
Thanks,
Bruce
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
This electronic transmission may contain confidential, proprietary or privileged information.  No confidentiality or privilege is intended to be waived or lost by erroneous transmission of this message.  If you receive this message in error, please notify the sender immediately by return email and delete this message from your system.  Disclosure, use, distribution or copying of this message, any attachments thereto or their contents is strictly prohibited.
More information about the mapguide-internals mailing list
