[mapguide-internals] MapGuide RFC 112 - sqlite based tile cache
Zac Spitzer zac.spitzer at gmail.com
Thu May 12 00:13:12 EDT 2011
answers inline
On Thu, May 12, 2011 at 12:56 AM, Traian Stanev
<traian.stanev at autodesk.com> wrote:
> Hi Zac,
> "Generating tiles is currently done using a rather brute force approach, by storing tiles in a database, it can be queried for existing tiles and only missing tiles can be requested."
> What do you mean by brute force? Doesn't tile existence checking come down to a file existence check?
By brute force, I mean that if mapguide goes down in the middle of
seeding the tile cache,
every tile needs to be requested again, which involves a lot of http overhead.
> "Using a sqlite database will use less disk space than a disk based tile cache."
> Do you have some numbers about the expected improvement? Inside its file, SQLite is basically a file system which will exhibit incomplete page filling and overflow, similar to a regular file system.
Individual files waste a lot of disk space, depending on the tile size
and file system block size,
I'm not a expert on this, but I'd expect a sqlitedb to be much more
efficent. Similiar to
what would be achieved by zipping up a tilecache with zero compression.
> Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Saturday, May 07, 2011 3:12 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] MapGuide RFC 112 - sqlite based tile cache
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc112
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
