[mapguide-internals] Re-discussing RFC 111
Jackie Ng jumpinjackie at gmail.com
Thu Nov 3 22:44:33 EDT 2011
Hi All,
The release of Subversion 1.7 has overhauled the working metadata storage
mechanism and as a result, has somewhat monkey-wrenched the original plan
for RFC 111.
A working copy checked out under svn 1.7 no longer keeps a .svn directory
per directory in the working copy, instead only having a single top-level
.svn directory for metadata storage. If the installer was built from a svn
1.7 working copy, this will un-doubtedly be un-usable for anybody with a
pre-1.7 svn client
So what choices do we have now?
 1. Keep the original plans as-is, but we need to ensure that the machine
that will build the official installer is building from a pre-1.7 svn
working copy, and we need to make it clear to end users that if they have a
1.7+ svn client, they will need to do a svn upgrade of these viewer file
directories to take advantage.
 2. Go back to the drawing board on this RFC.
 3. Use a real VCS that doesn't break things like git/mercurial :P
Thoughts?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Re-discussing-RFC-111-tp6961498p6961498.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
