[mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Jackie Ng jumpinjackie at gmail.com
Tue Feb 7 22:59:03 EST 2012
Hi Trevor,
I gave this 64-bit build for a spin. Sheboygan loads up fine. There was some
mapagent communication issues, which I'm guessing is due to an existing
IIS-configured installation of MGOS 2.2 on my machine. Yeah, not an ideal
test environment, but if anything this tells me what needs to be done to
better support side-by-side IIS configured installations.
Is the build machine using SVN 1.6 and the latest build scripts from trunk?
Because apart from fusion, I don't see any of the svn metadata being
preserved in the web tier directories. The trunk build scripts preserve this
metadata.
Also is the PHP in this build the same as the one you referenced from
apachelounge? I've checked in this version (with the httpd binaries ripped
out) for the installer.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrade-to-VC10-and-GDAL-1-9-tp4337041p4374819.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
