[mapguide-internals] Re: PHP Web Tier unit tests failure
Jackie Ng
jumpinjackie at gmail.com
Fri Feb 17 04:28:00 EST 2012
Ok, I've figured it out.
The hostname:port in OgcWfsService.config.awd and OgcWmsService.config.awd
did not match the port number I had in the web tier I was running the test
suite against. Changing the port numbers to match made these failing tests
pass.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/PHP-Web-Tier-unit-tests-failure-tp4463731p4479147.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
