[mapguide-internals] Motion: Vote MapGuide RFC 125 - Support Google Street View in Fusion
Zac Spitzer zac.spitzer at gmail.com
Mon Sep 3 03:06:13 PDT 2012
the TOS are also, only from a publicly accessible website, sans login
On Mon, Sep 3, 2012 at 8:02 PM, Ted Yang <ted.yang at autodesk.com> wrote:
> Hi Jason,
> Thanks for the reminder, we will disable it when the Google base map is not in use.
> Best wishes,
> Ted
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Tuesday, August 28, 2012 2:38 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Motion: Vote MapGuide RFC 125 - Support Google Street View in Fusion
> This functionality has a strong likelihood to be in violation of the Google Maps API T&C in many cases, at least without an Enterprise agreement:
> http://googlegeodevelopers.blogspot.ca/2012/04/update-to-google-maps-api-deprecation.html
> "There are certain Maps API Services, such as Places and Street View, which you are permitted to use without a Google Map. This update clarifies that if you do choose to use a map with these services it must be a Google Map."
> Is the widget going to be smart enough to disable itself when not used with a Google base map?
> Jason
> On 22 August 2012 08:37, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
>> Hi All,
>> With the review finished I motion for a vote on:
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc125
>> +1 Bruce
>> Thanks,
>> Bruce
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
More information about the mapguide-internals mailing list
