[mapguide-internals] Motion: RFC129 - SWIG/IMake enhancements and enhanced Java wrapper API
Trevor Wekel trevor_wekel at otxsystems.com
Thu Jan 10 20:08:54 PST 2013
Hi Jackie,
+1 Trevor
The modification to the build and documentation process will likely cause some work for Autodesk.  I think their build scripts are quite different.
Switching to lower camel case for method names is more in line with Java standards.  It is good that the old wrapper is being supported for the time being since the name change will break all existing apps based on the Java API.  Both APIs will have to be maintained for a release or two if the decision is made to drop the old API wrapper.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: January 9, 2013 9:30 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Motion: RFC129 - SWIG/IMake enhancements and enhanced Java wrapper API
Hi All,
I motion for a vote on
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc129
+1 Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Motion-RFC129-SWIG-IMake-enhancements-and-enhanced-Java-wrapper-API-tp5026528.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
