[mapguide-internals] Timeout for WMS layers
Gabriele Monfardini gabrimonfa at gmail.com
Fri Nov 15 00:09:36 PST 2013
Hi Jackie,
Have you tried setting a custom timeout for the WMS provider in
> serverconfig.ini?
> http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni#ServerFDOConnectionTimeoutCustom
I thought that that parameter controls only connection timeout and not
response timeout.
In my case the connection to the WMS server succeeded immediately, only the
response with the image took a lot of time and in the end failed.
The problem affecting WMS server is now solved so I cannot do more tests,
but I'll try to set a custom timeout just in case.
Regards,
Gabriele
More information about the mapguide-internals mailing list
