[mapguide-internals] Running multiple mapguide daemons on centos
Gabriele Monfardini gabrimonfa at gmail.com
Fri Jan 24 10:22:47 PST 2014
Hi, I was trying to run two different MapGuide daemons on centos (for
testing purposes).
I've changed MapGuide and apache ports.
However after starting the first, the second refuses to start.
Looking at strace it appears that it's trying to lock
/var/lock/mgserver/mgserverd.lock.
Since this lock is hold by the other mapguide, it gives up.
Is the position of this lock configurable in any way, at least per-version?
Regards,
Gabriele Monfardini
More information about the mapguide-internals mailing list
