[mapguide-internals] Patch for ticket 1657 (64-bit Linux support)
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Oct 9 07:41:56 PDT 2014
Looks good to me.
You can make the years in the copyright for the new files you added just be 2014.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, October 09, 2014 1:16 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Patch for ticket 1657 (64-bit Linux support)
Hi All,
I've made a patch for ticket 1657
http://trac.osgeo.org/mapguide/ticket/1657
This patch changes the typedefs of
INT8/UINT8/INT16/UINT16/INT32/UINT32/INT64/UINT64 on Linux to match the typedefs for these equivalent data types in FDO.
With this patch, the MapGuide test suite (sans Coordinate System tests) will fully pass and fixes the 2 blockers for 64-bit Linux that I identified in this thread:
http://osgeo-org.1560.x6.nabble.com/Any-version-of-MGOS-64bit-on-Linux-available-td5158750.html
For reference, the items mentioned are:
3. MapGuide feeds incorrect AGF binary data to FDO in 64-bit linux. Causes MapGuide-issued spatial queries to fail as FDO is not creating the correct FDO query geometries from the byte array fed from the MgAgfReaderWriter 4. MgMapBase destructor segfaults when attempting to save a MgMap. This breaks any attempts to save map state and prevents the AJAX and Fusion viewers from properly initializing (as both do a MgMap.Save() as part of its
initialization)
Please review. Thanks.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Patch-for-ticket-1657-64-bit-Linux-support-tp5166587.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
