[mapguide-internals] Review/Discuss: MapGuide RFC 149 (Lightweight MapGuide Source Tree)
Jackie Ng jumpinjackie at gmail.com
Thu May 28 19:40:42 PDT 2015
Hi Andy,
These OEM directories will stay inside MgDev:
 - agg
 - fusion
 - fusionMG
Everything else is moved out.
AGG has its source code files referenced directly by the Renderers project
on Windows, so moving that directory out is impractical
fusion isn't so much an "external library" but a framework built on top of
MapGuide that just happens to sit in an external repository, so there isn't
much sense moving that out either.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Review-Discuss-MapGuide-RFC-149-Lightweight-MapGuide-Source-Tree-tp5207824p5208099.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
