[mapguide-internals] Review/Discuss: MapGuide RFC 149 (Lightweight MapGuide Source Tree)
Jackie Ng
jumpinjackie at gmail.com
Thu May 28 21:12:27 PDT 2015
Yes, you would branch Oem along with MgDev whenever you make a release
branch.
So consider the hypothetical trunk under this RFC:
/trunk
/MgDev
/Oem
If you were to make a 3.1 branch, I suggest:
/3.1
/MgDev -> branched from /trunk/MgDev
/Oem -> branched from /trunk/Oem
And then make the necessary svn external URL adjustments for fusion and
CS-Map as you do before.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Review-Discuss-MapGuide-RFC-149-Lightweight-MapGuide-Source-Tree-tp5207824p5208104.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
