[mapguide-trac] #237: Add "--with-unixODBC" to PHP config for Linux installs
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 2 14:10:36 EDT 2007
   Reporter:  jdcard        |       Owner:
       Type:  enhancement   |      Status:  new
   Priority:  medium        |   Milestone:
  Component:  Build System  |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 Although ODBC is required for MGOS FeatureSource joins (and therefore will
 be installed in many cases because of this), the PHP install script does
 not include ODBC support. MGOS applications running on Linux are even more
 likely to use PHP as the development environment (than in Windows) and
 ODBC support in PHP will make code more portable between the two operating
 environments.
 Please revise the install procedures to include ODBC support in PHP by
 default.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/237>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
