[mapguide-trac] #237: Add "--with-unixODBC" to PHP config for Linux installs
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 8 00:18:11 EDT 2007
 Reporter:  jdcard        |         Owner:
     Type:  enhancement   |        Status:  new
 Priority:  medium        |     Milestone:
Component:  Build System  |       Version:
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Comment (by jdcard):
 Sure, as soon as I get it working I'll be happy to document the steps. So
 far I've tried adding the with-unixODBC parameter to the build_apt.sh
 script, but that by itself doesn't seem to be enough to get full ODBC
 support in PHP.
 I've not tried to build on Windows, so I have no idea whether this was a
 problem there. That config option doesn't appear in php_info on Windows
 and the php.ini file indicates that ODBC support is built-in, so I'm
 guessing that it is just not an issue in that environment -- ODBC just
 works.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/237#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
