[mapguide-trac] #243: Server errors are never reported with AJAX Viewer
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 14 17:44:15 EDT 2007
   Reporter:  jcarranz     |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  minor        |    Keywords:
External_id:               |
 Whenever a server error prevents the AJAX viewer from updating, there is
 no feedback indicating that a problem occurred. The map just stops
 working. This can be really confusing.
 Most significantly, whenever a session expires, the viewer should report
 that fact to the user.
 Also, the viewer API should have a hook for error handling, including the
 ability to override the default error handler. One example use for this
 feature might be some custom code for "rebooting" a session, or better
 display of error message.
 This problem may extend to the DWF viewer as well.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/243>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
