[mapguide-trac] #354: Problem in the GenerateFilter() method of the MgSelection class
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 3 11:38:39 EST 2007
   Reporter:  pchevalier       |       Owner:
       Type:  defect           |      Status:  new
   Priority:  medium           |   Milestone:
  Component:  Feature Service  |     Version:  2.0.0
   Severity:  major            |    Keywords:  bug GenerateFilter MgSelection FeatId
External_id:                   |
 I built a little web application that demonstrates the bug in the
 GenerateFilter() method of the MgSelection class.
 The bug seems to happen on a precise pattern inside the Feature Sources
 and only on the Identity field.
 The program demonstrate that no matter which SDF or SHP used (I only
 tested these two), the GenerateFilter() method returns a random ID instead
 of returning the correct FeatId (Identity).  You can use your SDF to test
 it too.
 Always the same FeatIds are wrong :
 It starts with the ID 248 for 4 polygons, and step by 256 after
 that.[[BR]]
 248, 249, 250, 251[[BR]]
 504, 505, 506, 507[[BR]]
 760, 761, 762, 763[[BR]]
 ... and so on.
 You can download the application at this address :
 [http://www.geomapgis.ca/webdownloads/MAPGUIDE_ERROR.zip]
 Start by reading the ReadMe.txt file.
 Be sure to give access to user ASPNET to your web folder application.
 Thanks to anyone that may have a solution to this problem!
 Sorry I posted on the Mapguide User forum with this bug too.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/354>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
