[mapguide-trac] #365: Unclassified exception starting the server when an invalid locale string is specified in the serverconfig.ini
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 5 22:16:58 EST 2007
   Reporter:  stevedang  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  2.0
  Component:  Server     |     Version:  2.0.0
   Severity:  critical   |    Keywords:
External_id:  984467     |
 On a working server instance edit the serverconfig.ini and set the locale
 string to "Bob".
 Stop the service and start the server from the command line using
 "mgserver.exe run".
 An unclassified exception is generated and the server fails to start.
 Ideally an error indicating that the local string is invalid should be
 generated.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/365>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
