[mapguide-trac] #354: Problem in the GenerateFilter() method of
the MgSelection class
trac_mapguide at osgeo.org
Thu Dec 6 14:19:07 EST 2007
#354: Problem in the GenerateFilter() method of the MgSelection class
Reporter: pchevalier | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Feature Service | Version: 1.2.0
Severity: major | Resolution:
Keywords: bug GenerateFilter MgSelection FeatId | External_id:
Comment (by pchevalier):
Mapguide : Autodesk Mapguide Enterprise 2008 & Mapguide OpenSource 1.2
OS : Windows XP SP2
Replying to [ticket:354 pchevalier]:
> I built a little web application that demonstrates the bug in the
GenerateFilter() method of the MgSelection class.
> The bug seems to happen on a precise pattern inside the Feature Sources
and only on the Identity field.
> The program demonstrate that no matter which SDF or SHP used (I only
tested these two), the GenerateFilter() method returns a random ID instead
of returning the correct FeatId (Identity). You can use your SDF to test
it too.
> Always the same FeatIds are wrong :
> It starts with the ID 248 for 4 polygons, and step by 256 after
that.[[BR]]
> 248, 249, 250, 251[[BR]]
> 504, 505, 506, 507[[BR]]
> 760, 761, 762, 763[[BR]]
> ... and so on.
> You can download the application at this address :
> [http://www.geomapgis.ca/webdownloads/MAPGUIDE_ERROR.zip]
> Start by reading the ReadMe.txt file.
> Be sure to give access to user ASPNET to your web folder application.
> Thanks to anyone that may have a solution to this problem!
> Sorry I posted on the Mapguide User forum with this bug too.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/354#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
