[mapguide-trac] #369: MgClassDefinitionCollection::Remove(MgClassDefinition value) returns a wrong value when the instance of MgClassDefinitionCollection is empty.
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 10 21:18:32 EST 2007
   Reporter:  jessicacao  |       Owner:  Tom Fukushima
       Type:  defect      |      Status:  new
   Priority:  medium      |   Milestone:  2.0
  Component:  General     |     Version:
   Severity:  major       |    Keywords:  MgClassDefinitionCollection::Remove
External_id:  1014109     |
 1. Construct an instance of MgClassDefinitionCollection using the
 following code
 MgClassDefinitionCollection classDefColl = new
 MgClassDefinitionCollection();
 2. Construct an instance of MgClassDefinition using the following code
 MgClassDefinition classDef = new MgClassDefinition();
 3. Use the method Remove(MgClassDefinition value) to return a bool type
 value.
 Sample code:
             Assert.IsFalse(classDefColl.Remove(classDef));
 Expect result:  False
 Actual result:  True
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/369>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
