[mapguide-trac] #371: Clicking on a point feature does not select it unless you click close to the insertion point
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 11 19:30:36 EST 2007
the insertion point
   Reporter:  tomfukushima  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.0
  Component:  General       |     Version:  2.0.0
   Severity:  major         |    Keywords:
External_id:                |
 1) Create a point layer
 2) Create a map based on the point layer, and make the layer's features
 selectable
 3) Try to select a point feature
 You need to click within 2 pixels of the center of the point in order to
 select it, even if it uses a large symbol.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/371>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
