[mapguide-trac] #374: MgPropertyDefinitionCollection:: Remove(MgPropertyDefinition) returns a wrong value when the collection is empty
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 18 02:23:31 EST 2007
   Reporter:  jiab     |       Owner:  Trevor Wekel
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  2.0
  Component:  General  |     Version:
   Severity:  minor    |    Keywords:  MgPropertyDefinitionCollection, Remove
External_id:  1014123  |
 Step to recur:
 1. Construct an instance of MgPropertyDefinitionCollection using the
 following code
   MgPropertyDefinitionCollection propDefColl = new
 MgPropertyDefinitionCollection();
 2. Construct an instance of MgPropertyDefinition using the following code
 MgPropertyDefinition propDef = new MgPropertyDefinition("propName",
 MgPropertyType.Boolean);
 3. Use the method Remove(MgPropertyDefinition value)to return a bool type
 value.
 Sample code:
   Assert.IsFalse(propDefColl.Remove(propDef));
 Expect result:  False
 Actual result:  True
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/374>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
