[mapguide-trac] #225: WMS GetFeatureInfo Returns Data From Only One Layer
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 6 19:43:06 EDT 2007
   Reporter:  jdcard         |       Owner:
       Type:  defect         |      Status:  new
   Priority:  medium         |   Milestone:  1.2
  Component:  WMS Interface  |     Version:  1.2.0
   Severity:  major          |    Keywords:
External_id:                 |
 WMS GetFeatureInfo should return data for all visible layers included in
 the request. It is only returning data for one layer.
 Environment: MapGuide OS 1.2.0 RC2 on Windows 2000 Server; Sheboyban data
 set.
 Open the Buildings layer in Studio and enable the URL, NAME, and ID
 columns in the "Properties displayed in Viewer" section.
 Load the http://SERVER/mapguide/mapagent/getfeatureinfowmsform.html form
 and change the following fields:
   Map Layers (comma-separated)      :
 Samples/Sheboygan/Layers/Parcels,Samples/Sheboygan/Layers/Buildings
   Query Layers (comma-separated)    :
   Query Point X (pixels from left)  : 300
   Query Point Y (pixels from top)   : 300
   Bounding Box (minx,miny,maxx,maxy):
 -87.727526,43.744432,-87.727157,43.744819
   Display Width (pixels)            : 600
   Display Height (pixels)           : 600
 Submit the form. You will receive a text/xml document similar to this:
  <FeatureInfoCollection>
   <FeatureInfo>
   <Property name="URL" value=""></Property>
   <Property name="NAME" value=""></Property>
   <Property name="ID" value="8231"></Property>
   </FeatureInfo>
  </FeatureInfoCollection>
 Next, reverse the order of the layers in the MapLayers and QueryLayers
 fields of the form. Submit the form and you receive something like this:
   <FeatureInfo>
   <Property name="Description1" value="ORIGINAL PLAT"></Property>
   <Property name="Zone" value="EXM"></Property>
   <Property name="Acreage" value="0.62"></Property>
   <Property name="Lot Dimensions" value="150X180"></Property>
   <Property name="Owner" value="IMMANUEL EVANGELICAL"></Property>
   <Property name="Description2" value="LOTS 7,8 &amp; 9 BLK
 224"></Property>
   <Property name="Description3" value=""></Property>
   <Property name="Billing Address" value="1634 ILLINOIS AVE"></Property>
   <Property name="Lot Size (SqFt)" value="27000"></Property>
   <Property name="Description4" value=""></Property>
   </FeatureInfo>
 Both queries should have returned data for both layers, something like
 this:
   <FeatureInfo Layer="Buildings">
   </FeatureInfo>
   <FeatureInfo Layer="Parcels">
 224"></Property>
   </FeatureInfo>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/225>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
