[mapguide-trac] #224: Poor error message from "MapGuide Site Administrator" when server not running
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 9 11:34:11 EDT 2007
running
 Reporter:  rajavijaysingh  |         Owner:
     Type:  defect          |        Status:  reopened
 Priority:  medium          |     Milestone:  1.3
Component:  Map Admin       |       Version:
 Severity:  minor           |    Resolution:
 Keywords:                  |   External_id:
Changes (by tomfukushima):
  * status:  closed => reopened
  * severity:  blocker => minor
  * summary:  Not able to login "MapGuide Site Administrator" => Poor error
              server not running
  * priority:  high => medium
  * milestone:  => 1.3
  * resolution:  invalid =>
Comment:
 I've changed the summary of this defect.
 We should see if we can detect in the Site Admin that the server is not
 running and display the appropriate error message.  The current error
 message does not point the admin to the actual problem.
 Even though this was found against 1.1.0, the same behavior can probably
 be found in 1.2.0.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/224#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
