[mapguide-trac] #226: Buffer is not Accurate
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 11 17:32:03 EDT 2007
   Reporter:  cgountanis       |       Owner:
       Type:  defect           |      Status:  new
   Priority:  high             |   Milestone:
  Component:  Drawing Service  |     Version:
   Severity:  major            |    Keywords:
External_id:                   |
 Seems when you do buffers the end result is 3 times smaller than it should
 be. 33 feet barely gets you into a road. 33 meters gets you across the
 road. Is there a solution to this mis-calculation. If a customer does 100
 feet buffer and it only shows about 30 we have an issue correct?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/226>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
